Проблем в таблото на Фокус
- iv4oto76
- Регистриран: 29 юни 2007, 00:46
- Модел на автомобила: Focus 1.6 16V SW 100 hp
- Местоположение: Pleven
намерих нещо интерсно http://www.usedcarmart.co.uk/forum/arch ... -1291.html" onclick="window.open(this.href);return false;
pac6204-07-2006, 01:26 PM
Hi
We had this problem with my focus. You need to get the vehicle speed sensor changed. I went to a ford dealer and bought the sensor (about £10) then took it to a garage who charged the same to fit it. Would of done it myself, but its located on the gearbox and has a retaining pin (which is a swine to get out).
Hope this helps
I like to thank this person. Your thread was invaluable. A new speed censor was bought and installed by my mechanic and now the fault has been fixed. Both Ford and my mechanic didn't think this would work, but it did. I spent lots of money trying to sort this problem out without success and like some of the others who have posted replies on this forum, my mechanic would always tell me that he couldn't detect a fault, but of course we knew there was one. I was experiencing the same problems as others, loss of speed (power surge) speedometer dropping to zero etc. The problem got worse and started to become dangerous so thank you very much PARC62!!!
Hi
Hope this helps
- iv4oto76
виж тук http://www.ffclub.ru/forum/index.php?ac ... id=1234422" onclick="window.open(this.href);return false;
- traqn_savov
- Местоположение: VARNA
Тея щифтове не излизат
че и се чупят от късо.
Траян Савов:
Траян Савов:
- iv4oto76
преди два дена ходих на майстор и той успя да извади щивта и смени датчика за скоростта и проблема изчезна въпреки че и МП - Плевен и няколко други майстори не вярваха проблема да е от датчика. А в един английски сайт http://www.honestjohn.co.uk/carbycar/index.htm?md=116&" onclick="window.open(this.href);return false; даже този проблем го дават като фабричен за Форд Фокус.
"Focus speedometers dropping to zero can be due to a failure of the vehicle speed sensor (VSS) plugged into the final drive. A clean of the contacts can fix it but more usually it needs replacing at a cost of £100 - £150. The fault may affect other instruments and warning lights. The traction control warning light may come on along with the engine warning light. Indicated fuel economy might drop. Acceleration might be affected. Problem of all Focus models suddenly losing power may also be be due to the failure of the 'fly by wire' electronic throttle sensor. Or hydrocarbon build up in the throttle body."
За да обобщя когато се появи проблема отидох в МП - Плевен и като обясних за проблема ми казаха категорично че това е платката в таблото "така става като превъртат километража" и сега трябва ново табло 550 лв. След това успях да открия човека в Плевен които се занимава с превъртането и той ми каза че "тази кола не е превъртана" и проблема е най - вероятно в VSS. Тогава започнах да търся повече инфо по проблема и колкото повече четях се убеждавах че това е причината.Преди около две седмици си купих датчика от МП - 85 лв. и естествено попитах могат ли да го сменят там и отговор "да за няколко часа и най - вероятно трябва да се сваля скоростната кутия цена 100-200 може и повече" Естествено тази цена не ми хареса за смяната на един датчик за това пробва при кварталния майстор и наистина не беше толкова лесно не стана работата щивта който държи VSS беше клеясал и не излизаше поне помолих да го напръска с спрей. И така две седмици и нов опит и то успешен без да се сваля скоростната кутия.
Дано тази тема е полезна на други колеги с подобен проблем
- debug
- Регистриран: 07 фев 2007, 01:29
- Модел на автомобила: триврат Focus Zetec 2.0 99г; Mazda 626 GC купе 84г.; BMW E36 96г.
Аз само не мога да разбера в Мото Пфое глупави ли са или просто искат да ни изцедят и последния лев.... В сервизното ръководство са описани стъпките за диагностициране на този проблем, като таблото се проверява в тестов режим, даже и без закачане на компютър. Следващата възможна причина е VSS. Все си мисля че това ръководство би трябвало да го имат и да го четат от време на време, а не да говорят наизуст. Някъде колега беше писал, че бяга от майстори, които четат ръководствата, е аз пък бягам от такива дето не ги четат.
- iv4oto76
и аз си задавам въпроса може ли в МП да не знаят за този проблем с датчика VSS на може би най - популярният модел Фокус. Като дори от централата на Форд признават за дефекти на VSS и на датчика за нивото на бензина. И защо в МП почти винаги имат този датчик наличен а нова платка за таблото не.
Изводите са два :
1. Ако не знаят за проблема а обикновените собственици на Фокус знаят това говори за много ниското ниво на техниците в МП и това че никои от тях не влиза в форумите. Защото и в Английски, Немски и Руски форуми на Форд има отделни секции за проблема и стотици постове на хора с този проблем.
2. Знаят за проблема и пробутват разни номера с табла, сваляне на скоростни кутии, диагностики и други.
И двата варианта не говорят добре за МП
Изводите са два :
- iv4oto76
какви двеста лева това е еба... инфлацията потърси го от някои друг град и ако го има - доставкаiv4oto76 написа:днес купих VSS датчика за скоростта цена 85 лв. от МП. Исках да го сменя още там но ме отказаха като ми казаха, че смяната ще отнеме час- час и половина за това ще пробва в някои друг
сервиз изглежда доста елементарно, но ще видим
- ptashkov
- Регистриран: 15 авг 2006, 14:20
- Модел на автомобила: Fiesta 1.25 Бензин 2009 г.
- Местоположение: Русе
Re: Проблем в таблото на Фокус
Значи и при мен се появи същия проблем с таблото-стрелката на скоростомера пада долу и на дисплея излизат само 4ертички и след това се оправя.Като пусна таблото в тест режим стрелките си работят, но на теста за грешки ми излизат две такива-кад d123 i д041-като след като проверих в нета се оказа че това е-първата е че не се подава или липсва информация за скоростта на превозното средство, а втората-че не се подава или няма информация на дисплея! Дали и при мен може да се окаже VSS датчик. Колата е фокус 1.6 '99 година.
- debug
Ми какво друго да е - стрелките ти мърдат в тест-режим и ти дава код за развален VSS
Значи е развален VSS.
focusfocus
- Регистриран: 22 яну 2008, 11:47
- Модел на автомобила: focus; 2002, Zetec 1.8 benzin, 16 V
Може ли да се връща километража успешно, и има ли начин да се разбере колко?
Потребители, разглеждащи този форум: Няма регистрирани потребители и 57 госта
