Една много готина цака с километража
Публикувано: 05 юни 2011, 23:29
				http://www.fordwiki.co.uk/index.php/Ins ... ostic_Mode" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;" onclick="window.open(this.href);return false;
Self Diagnostics Mode
The Self Diagnostics Mode gives you in-depth information about your
engine and the actual numbers in digital. To use it, follow the steps:
* Insert Key but do not turn it on
* Press and hold the Trip Meter Reset Button
* While holding the reset button, Turn ignition until dash lights come on and
continue holding the button
* Within 10 seconds, the display should change to "test" in LCD font
and the needles will do a full sweeping. Release the Button
Pressing the button will now cycle through some 17 different modes
* 1. Shows a Gauge Sweep
* 2. Shows all 8's on the LCD (LCD TEST)
* 3. Illuminates all the bulbs on the dash
* 4. Displays hexadecimal value for ROM level
* 5. Displays the hexadecimal value for EE level
* 6. Shows DTC (Diagnostic Trouble Code)
* 7. Digital Speedometer - mph
* 8. Digital Speedometer - kph
* 9. N/A
* 10. Digital tachometer
* 11. Fuel volume
* 12. Engine coolant temperature
* 13. Battery voltage
* 14. ABS fail
* 15. Electronic brake distribution (EBD) failure
* 16. Illumination
* 17. Crank Sense
Текста е на Англиски.Пробвах го преди малко работи утре ще заснема моите дани и да ги успоредиме с другите колеги.
Преведи написанотона български, не сме длъжни всички да знаем английски, в противен случай ще остане само линка и коментара на български, който си направил!
* 9. N/A
* 11. Fuel volume
* 14. ABS fail
* 16. Illumination
* 17. Crank Sense
